Averge Cost
As long as theres no welding you can get it done for around 100 dollars in under an hour. If theres no welding you might as well do it your self becuase cat-back is the easiest part to install.
Yea there is no welding or anything. I was thinking about doing it myself but my car is already at the paint shop getting some minor scratches out of it. They charge $65 an hour so i rather just have them do it so i dont have to deal with it and i know it is done right.
I've installed exhaust on both 01 and 03/04 cobra's. Same setup in both. It is about 30 or 40 minutes of works at most. I believe it was 3 bolts each side and two hangers. It is extremely simple. I would recommend doing it yourself. But if you insist on having someone else doing it, you should be able to get away with a shop doing it for $75 to $100. Just make sure they give you back all your stock parts.
-Edgar
-Edgar
jwog666
Dec 27, 2021 08:09 PM
