Installing Upper Intake Plenum(Tric Flow)
Old 09-14-2006, 11:24 PM
Bravesdude13
Bravesdude13's Avatar
Default Installing Upper Intake Plenum(Tric Flow)
i just installed a trick flow upeer intake plenum on my 99 gt and my check engine light came on and it was smokin a little...........also i have a code reader and it said ITA sensor 1 HIGH INPUT..........................WILL SOMEONE PLEASE LEAD ME IN THE RIGHT DIRECTION WITH THIS THANKS
TRAVIS
Bravesdude13 is offline
Old 09-14-2006, 11:29 PM
2000GT4.6
2000GT4.6's Avatar
Default RE: Installing Upper Intake Plenum(Tric Flow)
You sure it wasn't IAT?
2000GT4.6 is offline
Old 09-14-2006, 11:32 PM
Bravesdude13
yeah it is my bad. Any suggestions??
Old 09-14-2006, 11:35 PM
2000GT4.6
2000GT4.6's Avatar
Look and see if you reconnected the IAT (intake air temperature) sensor on the front part of the intake piping, up by the air filter.
If your car is a 99-01 (early year 01) the IAT is a seperate sensor from the MAF, located a few inches towards the intake from the MAF. It is pretty small, round shaped, and has a two prong connector.
If its a 01 1/2+ car, the IAT is built into the MAF sensor. Check to see that your MAF is connected securely, and that there is no dirt on the sensors inside the MAF tube.
Old 09-14-2006, 11:40 PM
Bravesdude13
ight i will check that THANKS
Old 09-14-2006, 11:41 PM
2000GT4.6
2000GT4.6's Avatar
NP
Btw, this should not be causing the car to smoke. Is it really smoke, or is it just cold outside and doing its usual stuff that you would not be looking at if not seeing the CEL glowing?
Old 09-14-2006, 11:44 PM
Bravesdude13
its definatel smoke i figured its just running a little lean becuz of all the air flow becuz i also have a mac cold air induction does the computer need to reset itself or something?
Old 09-14-2006, 11:46 PM
2000GT4.6
2000GT4.6's Avatar
At no point should any CAI or anything else you do to the intake of your car cause it to smoke.
A lean condition would definatly not cause smoke, but you should not be getting one anyway because the MAF can compensate for any small differences intake boltons will make.
Old 09-14-2006, 11:47 PM
Cornbread01
Cornbread01's Avatar
disconecct the batery for 5 mins that will reset the comp... dont know if it will fix your smoke problem
Cornbread01 is offline
Old 09-14-2006, 11:50 PM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: Cornbread01
That will reset the CEL light, but honestly I do not believe that it takes any time to for the computer to "learn" the car like everyone seems to think.
Your computer is set to a certian tune. Its going to take the same inputs and make the same outputs every time, regardless of how long it has been running. Its all just a seires of "if you have this coming in, send this signal out" logic, nothing more.
Quick Reply: Installing Upper Intake Plenum(Tric Flow)
