tach install
RE: tach install
You dont need a tach adapter you need to splice in to the wire by the pcm on the passenger side pin #26 on 99 and up to get a singal if im undertsanding everything correctly http://www.mustanghowto.com/interior/Raptor/Removal.jpg
RE: tach install
either pin 26 or pin 104 you can tap.
this might help. this is the picture when you take the bottom pcm off
http://raptorperformance.com/Ford/Mu...0&%20wires.jpg
RE: tach install
correct just need a ground and a power from ignition which is the red wire comin off the harness. Hook it up to a volt meter to double check your power wire is the right one coming off ignition so it turns on and off with the key
09-10-2015 08:39 PM
