Tubular K Member
RE: Tubular K Member
I thought it pushed the wheels forward a little, which is a good thing.. Better wheel base = better highway speed+ handling...
That's next on my list, along w/ some of the tubular control arms...
JT
JT
I read that to on these forums too. When it's pushed forward, is it really noticeable to the eye? Does the wheel look like it's closer to the front of the fender then to the back? If you got tubular a-arms couldn't you fix it?
The way my car looks now, even after all of the new suspension stuff, the front wheels look really close to the back of the front fender well... I don't like it..
I've also heard that the Cobra Front Lower Control Arms push the wheels forward a bit, to increase stability.. If this is true, that may be a good choice as well...
Also, most of the tubular Control Arms do the same thing, by pushing the wheels/spindles forward just a bit... It's really not a bad thing at all... Seriously..
JT
JT
here guys i will post some pics for you it does push them fordward 3/4 of an inch for better track but not all company do this and it makes a tremendis amount of room i coult access my header bolts easier I could take my headers in and out no problem so here is what my car looks like with the tubulur k member soorry it pretty low.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
so don't worry as you can tell from the pics i got nothing to worry about but because how low i sit i rub a little in the fender well
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Matt's 95 Stang
10-05-2015 07:16 AM
