Sea Foam Rising!
#31
RE: Sea Foam Rising!
I don't know what's worse...all caps or all bold.
The chevron stuff is just a concentrate of what's already in gas. So while it's okay to run it every now and then, it's not a miracle techy thing. They also make concentrations of the chevron that is only sold commercially for auto shops to do that whole fuel system clean out.
As for Seafoam, I already pointed out what's in it. Lighter fluid, Isopropyl Alcohol and a light grade oil. None of which is found gas and all of the reason ('pale oil') that causes the smoking. Cheveron additives are already in gas thus they don't smoke.
#32
ORIGINAL: Matts00GT
If someone is dumb enough to actually pour water in their motor, then they are an idiot. I was being sarcastic earlier. It was to prove that just b/c something smokes, does not mean its working. Obviously sarcasm is beyond you.
#33
ORIGINAL: Derf00
#34
ORIGINAL: ackuric
never heard of water injection? lots of Forced inductionENGINES use it. It can also be done to cause a 'steam cleaning' effect. you're just dumb if you dump a bucket of water expecting your engine to compress it.
#35
I used seafoam for the first time on my car (70,000 miles), and I could tell a difference. It's really noticeable when you just rev the engine, it revs up and comes down much, much smoother than it used to.
I've used seafoam for years on my '82 Mastercraft skiboat... often gets water in the gas due to condensation in the tank. I've always used it in the fuel system. The stuff works. Period.
[sm=closed.gif]
[sm=closed.gif]
#36
ORIGINAL: ackuric
[b]my seafoam experience. first time i seafoamed, i did the same amount as the rest of the times i had in the future. 2 shooters worth, i got a huge smoke show, lasted 15-20 seconds. this very last time i seafoamed, same amount, only smoked 1 cloud, 2 seconds. so, is it just seafoam causing the smoke show? i followed my exact same routine the first, and last time.
that was probably b/c after the first time of using it, all the un needed deposits had been burned off, leaving little to nothing left to burn for the second application..... U jus solved the mystery!! If it didn't smoke as much the second time after following the same routine then it worked well the first time. That should be enough real evidence to close this case shut!!!
#37
This is ridiculous...
The only intake/engine cleaner I'll use is made by 3M. It's an aerosol-type spray used in the intake stream that cleans the entire plenum and even the valve stems.. I've used it w/ great results..
It's like $75 for everything though, the cleaner, the spray nozels, and some other stuff...
After that, talk to an old school MOPAR Guy.. He'll tell you to use ATF in small amounts in your PCV, followed by water... That would work better than IPA or Xylene...
JT
JT
yourmom6990
09-14-2015 10:52 PM
