Cat question
$61.95 from steeda. http://www.steeda.com/
The only problem is the they are not reliable.. some people say the work for a short amount of time then stop while others say they have worked for years.. I personally tried one and after about 3 months it died.. so I just boght a diablo tuner and turned them off with that... good luck.
no with the mil eliminators.. the ecu thinks that the o2's are fine and does not retard the timing.... but like I said just keep an eye on the check engine light because if after a while it comes on then you know that the eliminators died and then it will start to retard the timing.
Vrooom
Feb 21, 2016 05:25 PM
treesloth
Sep 28, 2015 07:03 AM
Sep 24, 2015 09:18 PM
