Will this get me 380-400 rwhp?
#31
RE: Will this get me 380-400 rwhp?
ORIGINAL: 4.698GT
Yes you can run 10 psi on the stock block with the STOCK compression ratio of 9.5:1!!! He is going to have 10.5:1 because he has a NPI motor that he is throwing PI heads on. That compression with that much boost on a hypertenic(sp) motor is gonna explode everywhere into little pieces. Thats why I keep saying turn the boost down. HP is fun, but you don't want to blow your motor up right after you put the thing togather.
ORIGINAL: Matts00GT
Lol you can run 12 psi on the stock block with no problems. But whatever you say bro.
ORIGINAL: 4.698GT
I don't think anyone tuning the car would tune it. They wouldnt want the responsiblity of fixing the thing when the rod snaps in half from the compression and boost. Tone it down to like 6, 8 tops and I think you get away with a nice chunk of HP
#32
Stop woa hang on! If he used cometic gaskets that are like .086 thick he will ba back at 9.5-1 compression and best of all the cometics are the next strongest thing to orings so you dont have to worry about blowing them. I think they even have a blowout waranty of some sort. This will help. So go ahead and PI swap just use thicker cometics so you can boost. http://forums.modulardepot.com/showt...threadid=51255
#33
ORIGINAL: yoteehunter
Another option would be to keep your stock NPI heads and get the Livernois PI Intake swap kit. http://www.livernoismotorsports.com/product.phtml?p=457 This will keep your compression stock and save you a few dollars from doing the full PI swap all at one time. Then get your blower cams and Mongoose kit and get your 350-400hp that you want at a much more engine friendly compression. Later down the road when you have more money saved you can add a forged shortblock and ported PI heads to complete you build.
09-17-2015 07:32 PM
09-16-2015 07:53 PM
