keyless remote
The on and off thing didnt work on my 97 GT.
i had to remove the LR panel in the trunk and short the 2 connectors in the gray plug. I dont have a FOB, but i tested it and doors locked and unlocked. Once you short the thing you than press a button on the FOB it its programed.
Take out the trunk liner and behind your left fender well inside your trunk you will see a little gray connector not plugged into anything with two connectors inside. Get a paperclip and put in into the connector to complete the circuit. Then turn the key to the on position and the locks should cycle through open and close then open again. Then press any button on the remote. Then take the key out. It should cycle through locking and unlocking agian. Remove the paperclip and try your remote. Thats how I did my 96 GT and it did the trick.
Don't you guys ever use Ebay Hell with going to Ford for this part,
http://cgi.ebay.com/ebaymotors/NEW-S...39070449QQrdZ1
