Stroker guys I need your help
Ok I have switched gears on what I wanted to do with my engine. I canceled my order for my shortblock. I found a machine shop here to bore my block .020 over. I have decided to Stroke this engine but I havent found a kit I like and that can handle enough power. So I am putting mine together on my own. I am ordering a stroker crank with 3.750 stroke. Should I stay with stock length rods? What size rods and cranks do you guys have? Thanks.
RE: Stroker guys I need your help
Wouldnt longer rods cancel the stroke you just added with the crank? Also wouldn't it be to long and it the head? I could be wrong so please explain why longer.
I don't know which rods/pistons you'll need, but you will need a longer rod with a different piston that has the wrist pin closer to the oil rings and shorter skirts. The easiest thing would be to look at the details of a full kit and see what size rods they are using and which pistons to get.
you should order the stroker rotating assembly as a kit and have it balanced. www.vtengines.com or livernois motorsports are good places to purchase from.
I'm not getting the kit for 2 reasons. 1. I don't have the money for the kit, it is easier to to buy the parts as I can and as I need it. 2. I can put togather a much stronger set up then the kits. I need to get the crank now so I can take the block and get it machined. I'm just wondering about the rods length.
