colder plugs?
Old Oct 24, 2006 | 07:13 AM
geetee03's Avatar
geetee03
Default colder plugs?
how much will running one heat range colder plugs affect your n/a performance?
Old Oct 24, 2006 | 12:00 PM
sweet99's Avatar
sweet99
Default RE: colder plugs?
You will most likely lose power with colder plugs. Why would you want to try colder plugs? Usually they are for guys running blowers which creates higher cylinder temps. Mark
Old Oct 24, 2006 | 12:09 PM
djb1187's Avatar
djb1187
u will knock off 5 tenths in the quarter mile
jk...they are used mostly for nitrous or other types of forced induction.
Old Oct 24, 2006 | 05:23 PM
geetee03's Avatar
geetee03
well i'll be running nitrous soon, thats why the colder plugs. i just want to know if it is worth it to be switching out the plugs when off the nitrous.
Old Oct 24, 2006 | 05:28 PM
03sonicgt's Avatar
03sonicgt
You can't really notice. But a little fyi, whenever your car is off the bottle now, it'll feel slow. It's the only bad part about nitrous.
Old Oct 24, 2006 | 05:32 PM
P Zero's Avatar
P Zero
You onyl need to run colder plugs if youre creating really high cyl. temps. I had to drop 13 heat ranges on my 302 ranger, they call for an autolite 45, I had to drop all the way to a 33 non resistor racing plug. I kept melting the 45's down, both electrodes. I had the heads milled so its around 11:1, ever since then only those racing plugs hold up.
-P.
Old Oct 24, 2006 | 05:34 PM
yellowgtstang18's Avatar
yellowgtstang18
im using stock plugs. just gap them closer together and u will b okay.
Old Oct 24, 2006 | 05:35 PM
geetee03's Avatar
geetee03
i won't run the nitrous all that much, mostly just at the track. maybe? thanx sonic, and that fuel rail adapter should be here this week[sm=smiley20.gif]
Old Oct 24, 2006 | 05:40 PM
geetee03's Avatar
geetee03
ORIGINAL: yellowgtstang18
i already bought them, i'll gap them at about .033.
i'll just see if there is a difference with them, it'll be good if there is no noticable difference so i can just leave 'em in for everyday driving.
Old Oct 24, 2006 | 06:11 PM
03sonicgt's Avatar
03sonicgt
Get some ngk tr6 plugs and youll be fine.
BOB ROME
Jul 26, 2023 01:54 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
lmurf60
Sep 24, 2015 10:07 PM
