70mm TB
Old Oct 26, 2006 | 11:36 PM
03 GT's Avatar
03 GT
Default 70mm TB
If I bolt this on to my stock plenum, will I notice ANY performance gains? All my car has is an intake and a catback.. Dont really want to spend $350-400 on a TB/plenum combo, their just wayyyy overpriced.
Old Oct 26, 2006 | 11:53 PM
Emanpimpster's Avatar
Emanpimpster
Default RE: 70mm TB
If you take a marker and trace around the inside of the tb(youll be writing on the extra 5mm of plenum) Then you can take off the plenum and use a dremel to grind off all the part that you marked so there isnt so big of an edge which should make it flow better. Then clean it out real good so you dont have shavings in your engine. That should help. I wouldn't expect incredible results but it should work.
Old Oct 27, 2006 | 12:06 AM
03 GT's Avatar
03 GT
Default RE: 70mm TB
Should I even bother buying only the TB? Or will that be $200 wasted?
Old Oct 27, 2006 | 12:11 AM
JJ03MustangGT's Avatar
JJ03MustangGT
Default RE: 70mm TB
for a stock 2v a 70mm gets decent gains, a 75 will make better numbers when more mods are applied.
Old Oct 27, 2006 | 12:27 AM
03 GT's Avatar
03 GT
Default RE: 70mm TB
Whats the inlet size of the stock plenum? Would a 70 or 75 mm be a waste on a STOCK plenum?
Old Oct 27, 2006 | 01:06 AM
Poobs's Avatar
Poobs
Default RE: 70mm TB
I would not have bought my 70mm plenum if I had not gotten a great price. There were gains but not the gains to justify hundreds of $$$$
I picked up a 70mm TB locally for $125.00
The brand is Professional Products
01blackgtconv
Aug 14, 2015 04:50 PM
01blackgtconv
Aug 10, 2015 01:25 PM
Redneck1465
Aug 8, 2015 10:39 PM
BoulderBronco
Feb 1, 2004 11:58 PM
redneck101
Jan 13, 2004 09:55 PM
