plz help im having so much trouble~!
Old Nov 1, 2006 | 10:29 PM
Mark99GT's Avatar
Mark99GT
Default RE: plz help im having so much trouble~!
hmm, my accufab fit perfectly, but it was on a 99. You know you have to kind of pull on the piece that holds the throttle cables because its under tension from the spring right? Is the hose difficult to get on because it is too short or because it wont fit over the nipple?
Old Nov 1, 2006 | 10:43 PM
bumpinwheels95's Avatar
bumpinwheels95
one hose wont fit right its this one...
[IMG][/IMG]
[IMG]local://upfiles/20830/42A7692D4AB44E2C8D0640E885B31708.jpg[/IMG]
[IMG]local://upfiles/20830/966B2E7CF3404406A4043301DBE99E03.jpg[/IMG]
Old Nov 1, 2006 | 10:45 PM
bumpinwheels95
its the long thin one that goes into the back of the plenum but the only things thats diff was that my stock plenum the nipple that goes on the hose was straight out towards the back of car this one cuts to the right... i dunno that the only thing besides the bolts on the throttle cable that go on the top right of the plenum that didnt fit
dopes that help mark
Old Nov 1, 2006 | 10:55 PM
bumpinwheels95
Old Nov 2, 2006 | 12:33 AM
djb1187's Avatar
djb1187
i just installed mine like 3 days ago. reuse the factory bolts for the throttle cable thing, It should go in perfectly, remember thats it under tension cuz the spring so hold it while ur tighten, and with teh vacuum hose in teh rear...yea its a pain, keep fighting with it is all i can tell ya. Good luck bro
Old Nov 2, 2006 | 03:33 AM
tstang2000's Avatar
tstang2000
I had the same problem with the hoses when i put it in my gt. I used the new "nipples" that were givin with the accufab TB that are in the TB and conect to the hoses(They are different then stock). They are alittle bigger y i duno. but i relized that you do have to get new hoses!! i went to autozone and picked up a new strip of hose and cut it so it would fit right. you will also need to do this for the one that fits in the front where it bends to a boot shape. I believe those were the only two i had to change was the one in the back and the one that bent in the front. If you can bring down the stock hose and tell them you need it to be (i believe) a size bigger then stock. that should fix the problem and obviously double check everything. After that mine started right up.
CS2007
Jun 25, 2019 09:45 PM
msavoia23
12
Jul 7, 2018 12:08 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
