Installing a shaker
Old Nov 2, 2006 | 10:42 AM
jmac72187's Avatar
jmac72187
corner carver
Default Installing a shaker
I have been looking at shakers on the internet, but I was wondering how they are installed. Do you need a different hood? How do they fit on stock hoods if they can?
Old Nov 2, 2006 | 11:13 AM
rainydayracing's Avatar
rainydayracing
Default RE: Installing a shaker
I haven't done it myself, but did contact the vendor about it. They said that you can use your existing hood (they give you a template to cut it out), and there is an applique that sorta makes it look like the shaker hood. IMO it would be better to find a true shaker hood on ebay (look at the mach 1, and you'll see the hood is different). Then again, I was thinking the same thing, but ROI seems better spent on a supercharger.
Old Nov 2, 2006 | 01:36 PM
trbuddy's Avatar
trbuddy
You use your stock hood. They send a template with the kit so you can cut your hood exactly to specs. The stock shaker hood for the mach1 does not fit the after market shaker because its sits a little bit further back.
mtgldr
Feb 3, 2024 09:00 PM
Sep 10, 2015 08:39 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
