Valve Seal Check?
Old Nov 3, 2006 | 05:18 PM
95_302_StangMan's Avatar
95_302_StangMan
Default Valve Seal Check?
Hey everyone. How do you check your valve seal. Or how do you check that the valves wont let compression out? How good of a seal does it have to be? I tried checking by blowing into the ports with soapy water around the valves and looking for bubbles. On 3 of my intake valves there is a very slow leak or bubble. What is your experience with this? Let me know anything you know about this. Thanks
Old Nov 3, 2006 | 11:04 PM
bullitt15's Avatar
bullitt15
Default RE: Valve Seal Check?
do a compression test and cylinder leakage test. 4.6s are ~155psi your 5.0 should be close to that. it is a relitive test so if all cylinders are the same, thats good. if theres one thats not the same, theres a leak. id imagine cylinder leakage testers are expensive, so have a mechanic do it if you dont want to buy one. if you have over 100k mi these tests are advised.
Old Nov 4, 2006 | 12:06 AM
oxfordgt's Avatar
oxfordgt
A cyl leakage test is very easy if you have an air compressor and a fitting that goes into the spark plug hole ($20 at auto zone). Listen for where you can hear air leak out. If its in the intake then it is valve related, exhaust valve related, pcv time for a new engine.
Old Nov 4, 2006 | 04:42 PM
95_302_StangMan
Thats very interesting but............ The heads are off the engine and on my deepfreeze. I need to know how to check and see if I will loose compression out the cylinders and into the heads and intake and such. Does anyone have an answer to this?
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
