IAC Cleaning Questions??? (advice needed)
Hey guys, As of recently my car has been doing the old 3-4 second crank over for cold starts, so I read it maybe the IAC. My questions are as follows: First-
I'm 99.97% sure on this but just for kicks-Is this my IAC?
Second is whats is the cleaning proceedure/ cleaning materials you guys use to do this? Thanks!
RE: IAC Cleaning Questions??? (advice needed)
will spraying solvents/carb cleaners in there mess with the electronic sensor? I can't really figure out a way to take the actual electronic sensor thing off.
That's a solenoid, not a sensor. It moves in/out to control the amount of air being allowed through the valve (which controls your idle speed). Just let it dry and don't use anthing that will leave a residue (make sure the fluid coming off is clean) and you'll be fine.
ORIGINAL: Machwon
