speedo question...
ORIGINAL: HotWheels301
I recently installed white face gauges on my 2000 GT. I left the clear bezel off while having my wife go down the highway with the cruise set at 55 mph. I was off about 5 mph, so I adjusted it and put the bezel back on. Be careful when taking the needle off. It takes a special little tool that came with the kit. I'm sure you can use a small screwdriver with no problem. If you don't think it's had a gear change, then it probably is the gauges. Good luck.
First, in order to take the bezel off it looks like you need to take the headlight/parking light switch off. How do I do that without breaking it?
So if I take the bezel off, then I have to get the needle off. How do I go about doing that?
Then, how do I correct it when I put it back on? Should I leave it off and drive then put it back on at the speed at which I know I am going?
Thanks for anyone with advice and to those who have posted already!
This might be to late of an answer. If you still have this problem all you need to do is...
before you start your car and after you take the clear plastic piece off your gauge cluster. Hold down your trip meter button. then start your car. if you look at it on the part where is says milage you should see it change and should test your bezel gauges. you should keep hitting the trip meter buttong untill you get to the letters ENG00 the G looks like a 6 that is your digital speed. go down a clear road with the bezel needle off and get the cruise on at 30 MPH or what ever that is even. then place the needle on and take teh cruise and check the needle with teh digital reading. Dont know if it makes to much sense but if need any more help email me at
MGARCIA13@***.net
PS you should check all your gauges just in case
MGARCIA13@***.net
