interference...
Old Nov 10, 2006 | 04:19 PM
geetee03's Avatar
geetee03
Default interference...
there was a thread not to long ago about interference on a DOHC. is the SOHC an interference motor? and how often should you replace the timing chain?
Old Nov 13, 2006 | 06:35 PM
geetee03's Avatar
geetee03
Default RE: interference...
bumper
Old Nov 13, 2006 | 07:03 PM
bleau's Avatar
bleau
ORIGINAL: geetee03
I asked the same question about it being an interferance motor DOHC.
The answer I got was Yes it is.
As far as changing it I've never heard of it being an maintance interval type change could be wrong.
Someone else chime in on that one.
Old Nov 13, 2006 | 07:06 PM
JimboGT01's Avatar
JimboGT01
that just went way over my head. What is the interferferance? Does it have to do with the timing of our cars?
Old Nov 13, 2006 | 07:23 PM
bleau's Avatar
bleau
ORIGINAL: JimboGT01
Interferance is piston to valve contact.
Example if you where to take your timming chain off rotate your camshafts your valves will hit your pistons.
Had it happen in a Saturn I used to own, it really sucked Had to buy all new valves.
Old Nov 14, 2006 | 12:55 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Interference = Yes.
Replace the chain when your engine wears out. Chains don't require changing nearly as often as belts...and the modern chain drives are capable of taking up the slack anyway (as opposed to the OHV chains that will lose timing as the chain stretches).
ORIGINAL: geetee03
Old Nov 14, 2006 | 12:58 AM
HpOoRwSeEr's Avatar
HpOoRwSeEr
^ GENIOUS!!! he has the answer to every tech question.
wilsonboud
Nov 4, 2010 06:45 PM
