Hookin up
Hookin up
Whats the best way that everyone has found to get GT to hook up. I do pretty good much better than my friends camaro's at the track but im still spinning pretty bad causung me to run only about a 8.6 in the 1/8.
RE: Hookin up
ORIGINAL: GT 281
drag radials like 2000gt said w/ some U/L control arms would also do the trick
RE: Hookin up
MT E/T Streets................When you go to let out with your stock tires. Almost make it like your pulling away from a stop light. Dont dump it, just feather it til you feel it grab then FLOOR IT TIL YOU SEE GOD!
RE: Hookin up
i use mt et streets almost a full slick with a few lines to make them dot approved, go in the water box smoke the tires in 2nd gear for a good second and dump the clutch at 4500-5000 at the line. well not dump let out quickly and that does the trick for me, oh and have 18lbs of air
RE: Hookin up
I have always herd with street tires to not burn out in the water box but to avoid it and just burn out enough to scuff the tires.
and i have been running 25 lbs on the track @ 13 i was spinning all the way down the track pretty much/
RE: Hookin up
yea i went to the track and went 13.3 @ 111 on street tires and had a 2.6 60ft so i need to try some tires what r the best drag radials? and size? i have 18" wheels i was thinkin 295/35/18 nittos they are 26.5 inches tall
5.0kid
05-26-2010 07:46 AM
