How to access ECU on 01
Two part question:
1) How to access ECU on 01 Mustang GT.
2) Ive seen some electronic equipement from gap in passenger door when it is open. Something is inside the fender. How to access that space?
Reason being, is that Im doing custom installation, and need access to ECU, and some space to install equipement. Thanks.
RE: How to access ECU on 01
Get a trim panel removal tool to remove the plugs that hold the passenger side kick panel and to loosen the rocker panel cover.The ECM is under the passenger side kick panel.
Here's a link that might help.
http://www.raptorperformance.com/For...1999to2004.htm
Sounds cool, where do I get the tool?
Also, do you know what Im talking about when I said some stuff inside fender? When you open passenger door and look into the gap, you can see some stuff in there. Looks like a perfect space to install equipment. How to access it?
