quick help please!!! ring gap??
Old Nov 17, 2006 | 11:08 PM
99roushgt's Avatar
99roushgt
Default quick help please!!! ring gap??
does anyone know where i can find the specs for what the ring gaps are suppose to be on a 4.6 2v... would they be the same as the mach 1 .. i believe it would be because its basically the same bottom end but i want to be 100% sure i can only find the ring gaps for a mach 1 any USEFUL help would be appreciated
Old Nov 18, 2006 | 12:51 PM
oxfordgt's Avatar
oxfordgt
Default RE: quick help please!!! ring gap??
Compression (top) 0.130-0.280 mm (0.005-0.011 inch),
Compression (bottom) 0.300-0.550 mm (0.0018-0.0022 inch),
Oil ring (steel rail) 0.150-0.650 mm (0.006-0.0256 inch)
Old Nov 18, 2006 | 02:18 PM
Colorado_Mustang's Avatar
Colorado_Mustang
I'm not disagreeing with oxfordgt, but the specs for piston rings can vary depending if they are aftermarket pieces. If you know for sure what you have is stock, what you find in a manual will work. Otherwise, go by the specs provided by the ring manufacturer.
BTW, these are the specs I found in a service manual:
Top Comp: .009" to .016"
Bottom Comp: .015" to ".025"
Oil: .006" to .026"
Don't forget the side clearance, too. It should be .0012" to .0032" based on the book I have.
ORIGINAL: 99roushgt
Old Nov 18, 2006 | 02:37 PM
99roushgt's Avatar
99roushgt
colorado your right there partner and oxford those are the exact stock specs and i appreciate the help but i had misplaced the ring gap sheet that came with my rings but i found it 2 minutes after i posted this so i went off those specs its pretty cool they give specs for turbo and supercharger setups and nitrous and so on so forth i just went with the supercharger gaps they provided man the file fit rings are a pain especially if you do it right and measure them perfectly to each cylinder
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Dathan
Oct 5, 2015 05:52 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
