cam help
Old Nov 20, 2006 | 01:46 AM
PerformanceRed4.6's Avatar
PerformanceRed4.6
Default cam help
i want to do cams as next mod, which cams would give me the most noticable lope. i want it be noticed, i will be going into internals in the spring as well as heads between now and then! are the crower or comp cams more noticable than the vt?
Old Nov 20, 2006 | 01:59 AM
handyandy's Avatar
handyandy
Default RE: cam help
picking cams really depends on how extensively built your motor is. If you have N/A you would probably not see much benefit from stage II cams over Stage I. Stage I is all you would need. Although if you want lope, stage II will have more lope. If you have forced induction you would benefit from a higher stage cam. I don't know about brands though.
Old Nov 20, 2006 | 02:07 AM
eventer289's Avatar
eventer289
Here is a link of Stage 1 VT cams. Click "VT" cams in the post.
http://forums.stangnet.com/showpost....22&postcount=1
Here are VT stage 2 cams
http://youtube.com/watch?v=B2CChpMO0cI
Old Nov 20, 2006 | 02:13 AM
PerformanceRed4.6
where is the stage 1 cams sound clip? the stage 2s sound really good! what stage 2 crower or comp cams sound any different than the vt stage 2?
Old Nov 20, 2006 | 02:15 AM
PerformanceRed4.6
the car will eventually have forged motor with some nice flowing heads and probably p 51 intake...and not sure if i will go with nitrous or boost but it will be awhile b4 i go with nitrous or boost...right now i have a 125 shot of nitrous on it, with full bolt ons.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
