Track suspension ideas?
RE: Track suspension ideas?
i dont know about you guys but im looking more into turning and manuvers rather then drag set up...
so for starters LCA, PANHARD, SFC?
any order you guys would suggest? id prefer learning to control the car by 2 peices/upgrades at a time so car doesnt over shadow me
thanks
thanks
ORIGINAL: mysticsvtcobra96
one word bro...steeda..contact those guys and tell em what you got and how much $ you have and they will hook you up..literally
When you call MM, tell them how you want to drive the car... they have different setups for turning corners vs. 1/4 mile. I'm setup for autocross.
I started with just subframe connectors, trailing arms, Eibach springs, and Bilstein shocks/struts, and caster/camber plates.
Stage two was K-member, a-arms, coil-over conversion, strut tower brace, and eurethane bushings
Next was converting the rear to tourqe-arm and panhard bar.
Final stage: Autopower roll-bar
Some guys i know who run in AI started with a coilover setup up front and steeda comp springs in the back, tubular a arms and K member. i dont really know how the setup on the rear was. now they run in AIX and its coilover all around, the rear axle setup is hard to explain, there is this big *** steel v shaped piece that goes from the bottom of the rear diff up to the transmission crossmember area or something...i dont know what the hell it was, all i know was that it worked well for them, im pretty sure their team is leading in the west... they sold me my suspension setup
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
09-01-2015 08:16 PM
