clutch squeaks, ne ideas?
RE: clutch squeaks, ne ideas?
i had a bad problem w/ this when i replaced my stock clutch cable and quadrant to the bbk, its like the cable its self acctually rubs on the plastic hole it goes threw in the firewall. it made a annoying squeak noise and also made the clutch alil harder to press. so wat i did was cut up the firewall piece the cable goes through and put a rag under it in order to raise it up so the cable wudlnt rub. works soo far............talk about ghetto riggin though
ORIGINAL: stonemonk9
ORIGINAL: roundman
tight metal cable on plastic quadrant = squeaks. you might try some dry lubricant like graphite on the two pieces to see if this quiets them down.
Black Mage
AmericanMuscle4.6GT
11-10-2015 02:06 PM
ccdguy
09-19-2015 05:20 PM
