intake manifold help!
hey guys, on non pi intake manifolds with the plastic water crossover, when they crack, where does it leak? I have heard it happens around the thermostat housing area. I have a pretty good leak on the bottom of the manifold under the thermostat housing where the manifold meets the block by the cylinder head. I don't know what to do, it leaks pretty good. I'm hoping to do a motor swap in april, but until then I'm lost. Thanks for any help you guys can give.
RE: intake manifold help!
if your upgrading in the spring you can just find a used npi intake cheap on ebay or corral.net in the classified area...i've seen them sell for $30. That would get you by until spring if you need a quick fix.
