Halo/Angel Eye Headlight Question
I just got a set of halo/angel eye headlights and was wondering if anyone has installed them on their own. What is the best way to wire the actual "halo" wires? and is there any other things I need to know before installing them?? Any help will do.
Thanks
Thanks
RE: Halo/Angel Eye Headlight Question
I got the Halo headlights for christmas andI spliced and soddered the two halo and two led lights (the three in the middle and the one on the inside towards the grill) together in to the parking light cord. I had to peel back the protective wire covering and when I opened it up there were three wires. One was black (negative) one was brown and one was white and green on the right and white and blue on the left. The black wire from the halos and leds connect to the black of the parking light and the white from the leds and halos connects to the brown of the parking light. With this setup and the ford factory alarm setup the halos and leds flash when you lock the car and believe me it looks great. Another thing was the screw with the circular disc and jagged prongs on the end on the back of the assembly is used to tilt the entire light assembly (high and low beams) up or down. I found with mine the wayI got themI could only see 10 feet in front od my car. Thw whole job took about an hour with help from afriend to hold the light while soddering. Aslo the original parking lamp is used in the new assembly.The instructions that come with them are complete crap and are half in chinese so I hopes this helps with your install.
[IMG]local://upfiles/57758/963A537941C44595B0333E7EC7ABE346.jpg[/IMG]
ORIGINAL: etep31
