OBD II reset process help
Old 12-06-2006, 09:17 PM
Milky
Milky's Avatar
Default OBD II reset process help
I drive a 96 GT factory OBDII and am going to reset my computer in the coming days. When I turn the car back over after being reset, its gonna need to relearn the idle, air/fuel curves if I'm not mistaken, but I can't seem to find that process anywhere.
If anyone can just put these steps to resetting the computer into a few short words it would be much appreciated!
Milky is offline
Old 12-06-2006, 09:20 PM
II 98 GT II
II 98 GT II's Avatar
Default RE: OBD II reset process help
turn the ignition to "on"
connect scanner to obdII port
read codes
clear codes
you're done
EDIT: are you doing this to clear codes on your computer or just to reset the computer?
II 98 GT II is offline
LetThePoniesRunFree
LetThePoniesRunFree's Avatar
I'm not positive, but don't you just disconnect the battery and ground the positve terminal that goes to the distribution box?
LetThePoniesRunFree is offline
sitnlopro99gt
sitnlopro99gt's Avatar
the ecu will reset it self after disconnecting the battery for a few mins and plugging back in
sitnlopro99gt is offline
Old 12-06-2006, 09:26 PM
Milky
Milky's Avatar
I can reset the battery without problems, I need the process involved in letting the computer relearn the idle and fuel/air mix. Its something like idle for 5min, then idle with air for 5 mins etc... I just don't know how to do it correctly.
Milky is offline
Old 12-06-2006, 09:28 PM
trance565
trance565's Avatar
normally i just drive it around ....
trance565 is offline
Old 12-06-2006, 09:34 PM
II 98 GT II
ORIGINAL: Milky
I've never heard of having to do this before. I don't know much about ecu's though.
Old 12-06-2006, 09:36 PM
Milky
Milky's Avatar
Ya i think I have in the past, just drove it around, but ive got 50 miles now its not perfect and frankly annoys the shoit out of me. Anyone have that process??
Milky is offline
sitnlopro99gt
I have never heard this either the ecu should be able to teach itself with the way I described
Old 12-06-2006, 10:40 PM
Milky
Milky's Avatar
Im suprised no one knows what I'm talking about, maybe I'm thinking of a different computer. After resetting the ecu the car turns over and revs good and high for a while until you set the idle. You tap on the gas and the ecu pulls the rpms up to about 2k before going back down. The fuel curves dont seem quite on. It is slowly getting better like the computer is learning but its not FIXED. Again any helps appreciated..
Milky is offline
Quick Reply: OBD II reset process help
