tar on my door?
RE: tar on my door?
I use Poorboys Bug Squash or Stoner Tarminator for getting off tar. You can also use a claybar if it still has residue left over. I don't recommend using the clay on chunks of tar.
RE: tar on my door?
ORIGINAL: Juztang
RE: tar on my door?
ORIGINAL: Dan04COBRA
Tar & Bug remover will work just fine.
I wouldn't use a clay bar, it'll just smear it around.
RE: tar on my door?
i use and always will use clean odorless mineral spirits....takes off everything including the resin that smears on our interiors from the butterfly in the a/c vent.......yes it is also safe on factory leather.....NEVER use acetone on paint or leather it kills the dye on the leather and melts the clearcoat on the paint.
RE: tar on my door?
ORIGINAL: DrBob
Why? I have been using it for years with better results than any other bug and tar remover.
ORIGINAL: Juztang
RE: tar on my door?
ORIGINAL: Juztang
I use a claybar once i get the big chunks of tar off. There is usually a yellowish stain leftover from the tar that I use the clay to remove. I don't like using clay on big chunks of tar because you are moving it back across the paint. Plus it is ruining the claybar. I like to use a product that is designed to take off tar. There is nothing wrong with using a claybar if there is a small amount of tar and just saying you shouldn't use it for big chunks.
ORIGINAL: DrBob
ORIGINAL: Juztang
RE: tar on my door?
Thanks, gents. This is honesly the best response I have ever gotten after asking a question. Usually, I have to fight to get more than one opinion. Thanks a lot for your time.
breaking
10-02-2015 01:27 PM
09-25-2015 06:58 PM
