tranny fluid
RE: tranny fluid
You should just do a fluid change. Easiest way is to pull the shifter, drain the fluid and fill it while the shifter is out from the top of trans. This is also a good time to upgrade to an MGW short throw. I would use royal purple synchromax fluid as well.
RE: tranny fluid
Not a bad idea to change the fluid, but not really necessary if youre not having any problems. If you have extra money and time, then sure, change the fluid and the shifter. But other than that, if its not leaking, you should be good.
Matt
Matt
treesloth
09-28-2015 07:03 AM
09-25-2015 06:42 PM
