Idle Problems
Old Dec 20, 2006 | 02:44 AM
znasrah's Avatar
znasrah
Default Idle Problems
I've been haveing idle problems the last couple of days.. whenever i stop my car comes close to cutting off.. and sometimes it does cut off.. the rpm gets low and goes back up and sometimes cuts off... what should i do
Old Dec 20, 2006 | 02:56 AM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: Idle Problems
You should buy a new IAC.
Then you should pay me $25 for excellent & redundant tech advice because Ford can't do anything right.
PM me for my paypal info.
JK....
Old Dec 20, 2006 | 03:00 AM
LetThePoniesRunFree's Avatar
LetThePoniesRunFree
Here I thought it was the euro tail lights causing the problem..........
Old Dec 20, 2006 | 03:05 AM
kylebgt's Avatar
kylebgt
Defiantly sounds like the IAC, I just had almost the same problem. My car would bounce back in forth between 500 and 800 rpm's rapidly. I gave the IAC a good cleaning and it has so far solved the problem.
kylebgt's Avatar
kylebgt
Probably should change your spark plugs while you are at it.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
