trouble with mid pipe install
Old 12-21-2006, 03:24 PM
amoosenamedhank
amoosenamedhank's Avatar
Default RE: trouble with mid pipe install
+1 on redass' double post PB blaster is good stuff. Impact always helps and that is the unversial I was talking about.
amoosenamedhank is offline
Old 12-21-2006, 03:27 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
ORIGINAL: amoosenamedhank
suck on my chocolate salty *****. [8D]
redass02gt is offline
Old 12-21-2006, 03:31 PM
Jskeezy84
Jskeezy84's Avatar
preciate the input. yeah i used pb blaster and that stuff works magic and we had an impact wrench. guess i just need to get that swivel and go at it again.
Jskeezy84 is offline
Old 12-21-2006, 03:35 PM
shadowfoxx
shadowfoxx's Avatar
yeah.. just follow redass's input.. that will work for ya.. just have pantience.. even with the correct tools.. it's still a pain in the ***.
shadowfoxx is offline
Old 12-21-2006, 03:42 PM
newb2000GT
newb2000GT's Avatar
I used a deep well, a universal joint, and a 12" extension and could reach all four bolts. I also used PB Blaster and an impact. Iused a 22mm open end wrench to remove the O2 sensors prior to dropping the pipe. It made it 100 times easier to get your hand up in around the passenger side bolts, especially when trying to thread the nuts on during re-install.
newb2000GT is offline
Old 12-21-2006, 03:49 PM
Jskeezy84
Jskeezy84's Avatar
yeah thats anotther question i ment to ask can i just lengthen the rear o2 sensors with some wire to allow them to reach the holes on the pro chamber? or should i just cut the wire and say the heck with the o2 sensor and just useem to plug the holes?? it is an o/r road mid pip so its gonna send a check engine light anyways
Old 12-21-2006, 04:01 PM
AJ06GT
AJ06GT's Avatar
A 3 ton jack's handle makes a hell of a breaker bar . If that thing can't break a bolt I'd like to see what can. Gotta be careful not to use too much torque with it though. If you do too much without soaking and it's REALLY tight it'll pop the head of that bolt right off with how much torque you can get with that sucker. Slides right onto socket handle too.
I'll probably borrow a buddy's impact wrench but it may be just as easy with a socket and the jack handle on most of these. I'm gonna go ahead and run by Advance Auto tonight and try to get the gasket I need, or at least get them to order it then pick it up tomorrow so I don't have to deal with places being closed for Christmas when I need to get parts. I'll grab some PB Blaster while I'm there also.
AJ06GT is offline
Old 12-21-2006, 04:24 PM
Jskeezy84
Jskeezy84's Avatar
anyone got any ideas about the rear o2 sensors?? extend them with wire or cut them off and use them to plug the holes in the prochamber?
Old 12-21-2006, 08:32 PM
amoosenamedhank
ORIGINAL: Jskeezy84
I just extend the wire and it worked great. Well it's kinda pointless now that my tuner turned the rear 2 off but until then I would just extend the wire.
Granatelli Sales
01-20-2020 12:34 AM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Luke9222
09-04-2015 06:46 AM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: trouble with mid pipe install
