Midpipe install help
Old Dec 23, 2006 | 01:53 PM
mustang_montana's Avatar
mustang_montana
Default RE: Midpipe install help
i used a swivel head 8 inch extrension along with another swivel head 3 inch and another swivel head adaptor, then a deep socket 15. worked perfectly. i get mine off in 2 seconds now now prob. itll seem so easy as soon as you get it off the first time, seriously its not so bad with a bunch of swivel head extensions.
Old Dec 23, 2006 | 04:05 PM
JJ03MustangGT's Avatar
JJ03MustangGT
i used a swivel socket. it took me about 30 mins to get it off. be patient, itll come off.
Old Dec 23, 2006 | 05:19 PM
rbstang's Avatar
rbstang
my midpipe was a PITA. i will never install another midpipe unless i have a lift. I will from now on take it to a shop... i mean $40 isnt much.
Old Dec 23, 2006 | 05:25 PM
JJ03MustangGT
i had a lift it made it a lot easier.....i had to go under the car once to tighten the same bolt. wow it made it 50x's harder. if you dont have a lift then i wouldnt bother. pay the little bit of money and get it installed
Old Dec 26, 2006 | 08:34 PM
97torchedgttt's Avatar
97torchedgttt
well i tried it with the swivel socket and got impatient and said **** it... so im gonna take it to a shop the only prob is i cant find anyone to put them on bcuz they dont have and cats
Old Dec 27, 2006 | 05:17 AM
FDNYBullitt's Avatar
FDNYBullitt
I've posted this before but I guess unless your doing this job it doesn't get read. The design of the stud and pipe combination is perfect---A Perfect Pain In The A**---. The pipe is bent just right so a deep socket doesn't quite sit right on the nut and a short socket is, well, too short. So what we do without even thinking about it is use a die grinder with a cut off wheel and cut the stud just below the nut. Now you can use a good 6 pt. short socket and swivel or an impact swivel socket and bingo, off it comes. Also, no need to replace the stud as it is way to long to begin with. I swear, some day I'm gonna meet a guy who tells me he is an Automobile designer/engineer and I'm punch him square in the mush, just for all of the stupid sh*t they come up with. These idiots should have to work on cars before they design anything,good luck.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
