Fog Lights Not Working?
Well my foglights weren't working when I bought the car, so the guy had installed some pep-boysish aux fog lamps that are remote-controlledand mounted them in the lower grill. I once hit the button on it and they stayed on while the car was parked, and drained my battery[:@]. They're ugly as hell, and really arn't that bright. Since I've had the car, the fog lights have never been on, and I think just once...the light on the switch came on, then never did again.
What could be the problem? Bad switch?How can I check? And if so, where can I buy a new switch???
Thanks.
Heres a pic of those butt ugly aux. fog lamps.
Thanks.
RE: Fog Lights Not Working?
I had those remote controlled lights on my old 93 lx 5.0 and couldn't tell u how many times I had to double back just make sure the fog lights were turned off.
Sorry no being able to assist with your current problem but those things can be a pain in the a**.
the relay is under the hood, if you have the manual it should tell you, i think it is one of the smaller ones in the fuse box under the hood. try switching positions with the 2 and see if that helps. i had the same problem and thought the bulbs were bad but it was just a faulty relay
Diode Dynamics
28
05-26-2022 12:02 PM
inyadreems
08-21-2015 09:10 AM
