O2 Sensor Question
Old Dec 26, 2006 | 12:26 PM
mdubb1914's Avatar
mdubb1914
Default O2 Sensor Question
OK, My service engine soon light came on today. The mechanic said it was the O2 Sensors. My question is how many O2 sensors due I need and where are they located on a 1999 for Mustang. Also would it the sensors change location if I have a Bassani X pipe? I know that may be a silly question but I just don't know. Thanks
Old Dec 26, 2006 | 12:34 PM
04mineralgreyGT's Avatar
04mineralgreyGT
Default RE: O2 Sensor Question
The location won't change but maybe a few inches unless you have long tubes. You have two 02 sensors and they are the rear most plugs on your pipes. You'll have one (on each side) up close to the header on the down pipe, and one on each side of the midpipe (these are the 02 sensors). Is your x-pipe an off road x? If so then you'll need some MIL eliminators (malfunction indicator light eliminators). I went with BBK and got them for just shy of 60 bucks. They work fine. If you have cats then you may need to replace your 02 sensors.
Old Dec 26, 2006 | 12:40 PM
mdubb1914's Avatar
mdubb1914
I have a Bassani with cats... So Do I need 4 O2 sensorstwo for each Pipe?
Old Dec 26, 2006 | 12:46 PM
04mineralgreyGT
There are a total of 4 sensors. Two heat sensors, and two 02 sensors. The rear most are the 02's. So just get 2
Old Dec 26, 2006 | 12:53 PM
mdubb1914's Avatar
mdubb1914
Thanks for the help man
Old Dec 26, 2006 | 12:55 PM
04mineralgreyGT
anytime
Old Dec 26, 2006 | 02:52 PM
Jskeezy84's Avatar
Jskeezy84
so if you get an o/r mid pipe and buy a tuner dont the tuners just turn off the rear o2 sensors???
Old Dec 26, 2006 | 03:44 PM
slow99GT's Avatar
slow99GT
Hey dont go out and buy new 02's they are really expensive.. its probably your rear ones anyways so just go get some mils... they are dumie 02's cost around 50-60.. and take like 10 min to install..
Jb145700
Aug 21, 2022 06:37 AM
04stangman
Sep 17, 2015 01:45 PM
Big Al's 03
Sep 16, 2015 07:31 PM
TfcCDR
Sep 14, 2015 12:08 PM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
