Transmission Fluid
I have an 01 Mustang GT and have just ordered the MGW shifter. I plan on installing it this weekend and am going to replace the transmission fluid as well. Since RP seems to be the best I am going to go with them but do not know which one to get: Synchromax or Max ATF? I have the Tremac 3650 tranny. Synchromax seems to be recommended for manual transmissions that specify automatic transmission fluid, multi-viscosity motor oil or straight grade motor oil. Max ATF seems to be recommended for all applications where Ford MERCON»® / GM DEXRON® III transmissions fluids are specified. Which one should I pick up? Also how much will I need?
jwog666
Dec 27, 2021 08:09 PM
Sep 25, 2015 06:42 PM
