Tranny problem...
Old Sep 19, 2004 | 11:20 PM
czwalga00gt's Avatar
czwalga00gt
Default Tranny problem...
I have an extended warranty that runs out in like 4 months so if my tranny is covered (ill have to check) i wanna get this fixed. If i'm idling in neutral for over 10sec... and push down the clutch and try to put it in reverse.. it grinds. If i put it in any other gear its completley fine... So when im idling and need to go in reverse or whatever.. i put it in first then to reverse and its fine. I dunno if this is the tranny clutch or what?
Anyone else had this problem?
Old Sep 21, 2004 | 01:54 PM
Guest
Guest
Posts: n/a
Default RE: Tranny problem...
I think it's just because the reverse gearing isn't helical, they're just straight teeth so they don't always mesh without a bit of a grind.
Everytime I roll out of a driveway, I'll throw it in R real quick and it always gives a little bit of a grind.
Old Sep 21, 2004 | 04:42 PM
czwalga00gt
I dunno, because if i very very slow try and put it in reverse.. i can feel the wheel spinning inside on the tranny or whatever.. hard to explain i guess.
Oh well not a big inconvienence.
Old Sep 21, 2004 | 04:49 PM
deesgt's Avatar
deesgt
I have the EXACT same problem in my 96gt. I keep my Stang in the garage and I pull it in. So anytime I drive it I have to back out of the garage. As soon as I slide it to reverse I can feel (the flywheel, I guess) spinning around and grinds quickly and that's that. Does'nt do it an any other gear. Have'nt tried to do it from another gear to reverse as opposed to from neutral to reverse. I was thinking my tranny was about to go or my clutch was gone.
Old Sep 21, 2004 | 06:20 PM
czwalga00gt
Yeah, I'd like to know whether its the tranny or clutch... if it's my clutch i know its not covered... but im not sure about the tranny. Or if this is going to be a bigger problem down the road.
Old Sep 21, 2004 | 09:00 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Isnt normal in mine. I can actually be rolling forward and slide it into reverse without any grind. I would get it checked if I were you.
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
prophotog
Sep 15, 2015 08:38 AM
jaiidutch
Sep 14, 2015 10:29 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
