Ok me and my dad hooked up my nx platekitjust like the instructions said (and they sucked.). We hooked up the purge like it said(that sucked to). Everything was just like the instructions said and i go to turn my bottle on and it blow out the purge tube....without touching anything.???? Idk what to do. Plz Help
You have the newer purge valve. I did the same thing and felt like a total idiot. Just remove the solenoid and blow through it....you can then see what is the inlet and outlet.
we did we reversed it and checked grounds and power and everything.. i dont know what it is.
My car is in the shop so I can't take a look right now[:@]But I do believe you have to plug the hole marked "purge". I won't have a chance to check until the weekend, sorry...........
I had that problem once.. is the sol facing the right direction?? I cant remeber what I did to mine to fix it[sm=headbang.gif]
I think I had the purg in the wrong location...
