Supercharger installed!!!
#41
RE: Supercharger installed!!!
Dynos are just a tool to help tune and see power gain using the same dyno with different mods. They very depending on a lot of variables. Goto the track and get a trap speed, thatll give you a better idea of where you're really at.
#42
ORIGINAL: stang2000
Here are his supporting mods.
2000 Mustang GT 4.6L
5 spd
BBK CAI
Bassani Catback
Bassani o/r X pipe
FRPP 4.10 gears
King Cobra HD clutch
Steeda Tri-Ax Short Throw Shifter
Novi 2000 supercharger
AFM Powerpipe
FRP 42lb injectors
90mm Lightning MAF
5 spd
BBK CAI
Bassani Catback
Bassani o/r X pipe
FRPP 4.10 gears
AFM Powerpipe
FRP 42lb injectors
90mm Lightning MAF
#43
also the whole gear thing is stupid... the reason your falling out of power IS BC YOUR GOING TO FAST... steeper gear = faster car , all else being equal (to a degree - which I shouldnt even have to say)... the reason he told you that is bc you might have to shift in the 1/4.. but make no mistake the car is faster... you have to decide if you want a faster track car or street car
#44
ORIGINAL: czwalga00gt
#45
you should see at least this much at the motor and not much less to the wheels drivetrain loss is only like what 15% or somethin?
http://www.paxtonauto.com/systems_1001832.html
#47
ORIGINAL: Car_Ramrod
if you dynoed on a superflow dyno then the numbers you got from that are LOWER than your numbers would be on a dynojet.
Galactic
04-29-2019 02:56 PM
Luke9222
10-22-2015 11:55 PM
ernesto-619
09-10-2015 01:32 AM
09-03-2015 07:14 PM
10, 10psiboost, 1213degrees, 2000, gt, mustang, psi, safe, steeda, supercharger, timing, wideband, wot
