Need HELP!!! MT ET street tire tubes!!!!!!!
I ordered tubes for my MT's from JEGS...
These are the tubes i ordered..
Drag Tire Inner Tube, Fits Tires: [*]24-1/2" to 28" Dia.[*]8" to 10-1/2" Tread
http://www.jegs.com/webapp/wcs/store...48721_-1_10721
I got the tubes and they say for 15"-16" rim, my tires are mounted on my 17" rims and are 275/45's......according to the specs of the tires these tubes should fit, but they are marked for 15 & 16 inch rims.....which tube will fit????
RE: Need HELP!!! MT ET street tire tubes!!!!!!!
ORIGINAL: code3GT
Did you get the MT Drag Radials? If so, you don't run tubes with them. You use tubes in the ET Drags or ET Street bias ply tires.
http://www.jegs.com/webapp/wcs/store...53925_-1_36694
so they are the Radials
The reason i wanted tubes was because they have a habit of picking up every stone around, and last summer i got a flat from one. Can you run tubes with them? or is that a no - no? If so which size? thanks Code
ORIGINAL: stanggang1892
These are the ones i have.....
ORIGINAL: code3GT
09-16-2015 07:53 PM
09-09-2015 10:30 AM
09-08-2015 11:50 AM
09-01-2015 08:16 PM
