Supercharger PSI
RE: Supercharger PSI
It depends on what DOHC 4.6 you have. The 03-04 cobras have forged bottom ends as well does the Mach 1 5-spd DOHC 4.6. Without a forged bottom end I would say 10-12 psi with an intercooler and a proper tune.
You don't have the forged bottom end with the auto Mach. But thats okay. Do you have a centrifugal s/c or a roots/twinscrew? Generally a smaller pulley with yield you higher boost #'s, yes. If you have a centrifugal you could look at an Anderson Ford Motorsport, UPR, or Steeda powerpipe (aka: boost pipe) and get another # or two of boost. I haven't seen any powerpipe for a twinscrew s/c other than what Kenne-Bell uses for their CAI (cold air intake). I think C&L Performance may have a CAI for a roots/twinscrew also. After looking harder at your original post I see you're running 5psi now. That leads me to believe you have a non-intercooled KB??? I would definately invest in an intercooler when you up the boost if the non-cooled KB is what you have.
i wouldnt run any more than 10 psi cause those mach 1 engines have high compression as it is so adding that much boost is not gonna do any good for it. Not to mention its a hard to tune a high compression car with a blower added.
ORIGINAL: bozzman
I have the Procharger with inter-cooler, P-1SC.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
10, 105, 46, boost, compression, crown, dohc, engine, high, increase, psi, rebuilding, running, supercharger, vic
