**help! burning oil**
i got my 96 gt abut a moth ago, i noticed that the low oil light would come on occasionally but i blew it off, about a week ago i got the oil changed and the light went away. now this morning the low oil light comes on again. can someone please give some advice on whats wrong?
Probably one of 3 things. You're burning oil because the rings are worn, you're leaking oil because your main seals are worn, and I'm not sure if the oil light will indicate this or not, but maybe check your oil pressure. Older cars almost always use oil, so it's not uncommon, but keep an eye on the level.
The first thing i would think you would check is for leaks. lol. I cant think of anything that usually goes on these years for oil problems. But maybe youres is beat. Also maybe youre oil pressure sensor is junk. Very common on 4.0 exp's and rangers. But first things first, check for leaks.
I agree with Casper. But my 96 Gt burned oil like a sumbitch so I just got rid of it. At the time rebuilding a 4.6 was very expensive. Im pretty sure it still is... Dunno, Im a 5.0 guy now
lincolnshibuya
Dec 8, 2015 04:37 PM
