90mm MAF too big?!
RE: 90mm MAF too big?!
ORIGINAL: rbstang
i would talk to code... but im pretty sure hes running the stock maf calibrated for 30lb injectors and he has more hp then... so how is your maf pegged?
If all you have is nitrous, then you def. don't need a 90mm. With the short blasts that you use the nitrous on your car won't run right without the no2. I would say stick with your stcok and get a mafia tuner. That'll open up the door to like 5v to where you'll never peg out. You can just turn it back when your not racing. They run around $150
Your MAF has nothing to do with nitrous... nitrous is injected into the engine after the MAF.
You either spray the nitrous in just before the t/b (along with the extra fuel required) or you have a system like the holley one where it increases the injector pulse for you. Even in that system, I am 99.99 percent sure the MAF has nothing to do with it.
The MAF cannot read the differnce between nitrous and air coming into the engine. Compressed nitrous is a completely different animal from regular air... aka it is not gonna read the same (per unit of fuel required).
I don't see how you are pegging even a stock MAF let alone a aftermarket one. This almost has to be an issue with your shop (unless the maf is just messed up). I have heard of several people in the very low 400 range "pegging" the 90mm lighting meter as well... its got to be their shop (the stock L meter makes more than that on a stock truck!)
ORIGINAL: 97targa
ORIGINAL: ZW99GT
I dont have anything near the amount of Air coming in that you do.
I'll be just fine with a 90mm and 24lbs. I was just making sure that I could calibrate this MAF to match my car/injectors.
ORIGINAL: droptoppony
you don't calibrate the MAF's on these cars to match injectors...its done in the tune. The MAF's that require you to trick the car with sample tubes such as C&L etc are not good. You should use the stock for most NA applications up to 350rwhp and a 90mmLMAF after that. If your going with big power then a SCT 2400 or 2800 is the next step. Those are the only 3 MAF's that i would use on a modular. Maybe a Pro-M blow through in a custom Turbo setup.
ORIGINAL: ZW99GT
ORIGINAL: rbstang
jwog666
12-27-2021 08:09 PM
