TIRE PRESSURE
Old Jan 28, 2007 | 05:12 PM
Brandons98GT's Avatar
Brandons98GT
Default TIRE PRESSURE
What is the best tire pressure for 245/45/17 to wear evenly and for 275/40/17 thanks
Old Jan 28, 2007 | 05:24 PM
SVTBill's Avatar
SVTBill
Default RE: TIRE PRESSURE
35psi will give you slightly better mpg, while 30 psi will give you a slightly better ride quality
Old Jan 28, 2007 | 05:42 PM
203Mach1ne's Avatar
203Mach1ne
32 psi ... happy medium
Old Jan 29, 2007 | 02:02 AM
Colorado_Mustang's Avatar
Colorado_Mustang
The most pressure you can put into the tire with the full width of the tread contacting the ground. You can check this with a chalk mark across your tread and moving the car around to find the wear zone.
Old Jan 29, 2007 | 02:04 AM
Fizzics Boy's Avatar
Fizzics Boy
ORIGINAL: 203Mach1ne
thats what i keep mine at
Old Jan 29, 2007 | 02:27 AM
lsustang04's Avatar
lsustang04
Anywhere from 32--35 psi for ride quality and gas mpg.
Old Jan 29, 2007 | 02:31 AM
Pitt's Avatar
Pitt
ORIGINAL: lsustang04
So if tire says 50 psi Max pressure, you keep it at 32 psi? If not, what is the Max psi stated on the tire?
Old Jan 29, 2007 | 02:37 AM
aMerICAn_mUsCLe79's Avatar
aMerICAn_mUsCLe79
the max that the tire can hold....alot of ppl do that and put 40 psi in there tire b/c the tire seys so, but always go my what the car seys (doorjam or manual)
Old Jan 29, 2007 | 03:24 AM
97targa's Avatar
97targa
ORIGINAL: Brandons98GT
The reality of it all is that it depends on the Tire manufacturer and Compund used to make it. The "doorjamb" pressure is just a precautionary measure to save the freakin car manufacturs *** incase a lawsuit comes into play. 35psi is really the best overall wear for MOST tires. It will be rougher on your suspension components and balljoints etc. A lower pressureized tire will get more bite, but can be punctured easier. Be aware when you put 40psi in your tire, this is not good, especially if you plan to run your car up over 100mph. At that speed your tire pressure raises roughly 6psi from where you measured it cold! Air expands when it gets warm! Wouldn't be a good thing. I like 35psi so I can take the turns hard and get even wear accross the bottom. I know it's even wear because I did a burnout at 30psi, 32psi, 34psi and 36psi...lol
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
marc954
Sep 29, 2015 11:18 AM
