Shifting issue?
Old Jan 29, 2007 | 02:20 AM
2000GTBoy's Avatar
2000GTBoy
Default Shifting issue?
I have a automatic tranny in my stang and i love to drive it like a manual but some time when i throw it in second it will rev rev rev shift. Like a sputter. I know its losing me time in the quarters so I DONT LIKE IT. what should i do?
HELP!!
Old Jan 29, 2007 | 02:48 AM
eventer289's Avatar
eventer289
Default RE: Shifting issue?
ORIGINAL: 2000GTBoy
HELP!!
Well start by never shifting it like a manual. Unless you upgrade to manual valve body your tranny can't handle being shifted like a manual. You have probably messed up something internally and the next gear isn't catching.
Old Jan 29, 2007 | 02:55 AM
97targa's Avatar
97targa
Your tranny has 2 sets of gears for 2nd. The Planetary gear drive set" and the sun gear set. with out a manual valvebody the bands cannot keep up with the rotating mass when you shift from one gear set to another. When you put your car in dirve you use the planetary set, and when you start your car in low or 1 then shift to 2 your driving with a completely diff. set of gears that are not meant to be shifted while moving. They don't have the same band function as the other! You prob have a loose or burned up band. They are basically like the oil filter wrenches that have a handle on them, but with brake pad material on the insides of them! You prob. should get a rebuilt tranny that's made for what you wanna do. $1400 plus install
Old Jan 29, 2007 | 03:44 AM
DSTANG03's Avatar
DSTANG03
thats what i was going to say bands are slipping!!
Old Jan 29, 2007 | 03:51 AM
CoolAid's Avatar
CoolAid
Can people with 99-03s upgrade easilly to a 4R70W? Always wondered that.....if so, I would look into junking the AODE and switching to the 4R70W if a new tranny is in the works.
Old Jan 29, 2007 | 03:58 AM
97targa's Avatar
97targa
You can do anything with the right bellhousing, tailshaft, driveshaft, crossmember..lol
Old Jan 29, 2007 | 04:02 AM
dubarado's Avatar
dubarado
ORIGINAL: CoolAid
it should bolt right up, altho certain things were changed here and there throughout production.... by all means i'd upgrade to a 4r70w... you can 'manually' shift them safely unlike the AODE trans.
Oct 7, 2015 07:02 PM
degner122
Sep 16, 2015 07:09 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Mustangmalo
Sep 6, 2015 05:22 PM
