I have an Auto...So how do I launch
Old Jan 30, 2007 | 02:04 PM
03fireredstang's Avatar
03fireredstang
Default RE: I have an Auto...So how do I launch
ORIGINAL: GotYouLooking
ORIGINAL: WAG03GT
ORIGINAL: fiad06
Hi my name is chris from ny, im new to this forum but had the same problem as you. like greg said you will hold the brake and rev up the engine to about 2500 rpm or untill you notice that the tires want to start to spin then you release.Also the best way to take advantage of your automatic is to use the old shift pattern (L)(2)(3)(D)(OD).Learn your cars peak point to shift each time.Try that and you should be good, but take it easy if you dont have a coolant for your tranny,it tends to get alittle bit hot.
It does not stall to 2500
Haha+1 its no where near 2500
Sorry dont know your point of rpm thats why I said OR. Mine is a 97 GT and is around 2500 rpm for my lauch
do u have a stall converter?
ctgreddy
Oct 14, 2015 09:05 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Oct 7, 2015 07:02 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
vintageaion
Sep 8, 2015 10:45 AM
