brakes
RE: brakes
ORIGINAL: Quickshift_02GT
Why not wait two weeks and get the premium, best performing setup instead of just getting by with an alternative?
The "cobra swap" is just cobra calipers and 13" rotors, THAT'S IT! You re-use the caliper mounting bolts, and the stock brake line works perfectly. In fact, the cobra brake line and GT brake line have the same part number.
Buy a set of Cobra calipers for $280 (yes they can be found brand new for this cheap), and find yourself a pair of 13" rotors. I paid $75 each for my slotted and drilled rotors. Tada, instant cobra brake kit.
Edit: When braking hard or accelerating hard, a brake light that comes on means you have low fluid. Check your pads first, if they are fine, just add some extra fluid. If they need replacement, replace them and then check the fluid.
RE: brakes
ORIGINAL: stoes
im buying these rotors and pads.. $190.
http://cgi.ebay.com/ebaymotors/ws/eB...310&rd=1,1
RE: brakes
They should be cracked within the month, the drilled holes do not even look chamfured. I picked up a set of bear decela rotors for 95 dollars at autozone on pricematch (fronts). These carry a three year warrenty.
RE: brakes
ORIGINAL: uofipilot
Yeah....let us know if these are good or suck. 4 drilled/slotted rotors and all pads shipped for less than 200?
ORIGINAL: stoes
RE: brakes
Saveup your moneyfor these 13 in solid rotors, red pony dual piston calipers, top quality ford parts. With your mods, Im sure you're driving your stang. You need good brakes.
http://www.americanmuscle.com/01bull...onversion.html
$450free shipping,easy install, more than enough brake for your GT . American muscle discount for forum readers. Enter "mustang boards"as yourdiscount code. it might be 10%, not sure.
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
