How low is too low?
How low is too low?
Hi
I have a 01 Gt and I just got some ABC version 1 side skirts, Razzi rear bumper cap, and a cobra-r 2000 front bumper. I am wanting to switch out my suspension so the car handles better but most kits lower the car like an inch or two. I havent measured how much im off the ground but it aint going to be by much. Do you guys with body kits have many problems going over speed bumps and stuff bottoming out? Or should I just go over bumps slow and ill be fine?
RE: How low is too low?
I had ground effects on one car that were already on the car when I bought it.They started breaking off shortly after.I replaced or repaired the damage as it happened.The last straw came when an unfortunate racoon ran out in front of me and cleaned the front air dam off the car.
To answer your question,how high is thetallestspeed bump in your area?That will give you the lowest height off the ground you can have body parts and still hope to keep them on the car.
It's not the speed bump you can see that kills you!!!!!
jwog666
12-27-2021 08:09 PM
Omgitsa88Stang
10-05-2015 07:33 AM
dalefrancis88
09-11-2015 07:15 AM
