fuel pump problem(help please )
Old Feb 14, 2007 | 05:24 PM
mariotraci's Avatar
mariotraci
Default fuel pump problem(help please )
i thought my fuel pump was bad. so i took it apart and got a new pump and it does the same thing my other one did witch is it makes a quick surge(pump makes a little jump)and then nothing pump shuts off.my car wont sart
is there any relays,regulatori no it proby be something small BUT I NEED SOME HELP
Old Feb 14, 2007 | 05:30 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: fuel pump problem(help please )
here's a link to the other thread nearly identical to yours...funny thing posted today as well.
https://mustangforums.com/m_2718931/tm.htm
Old Feb 14, 2007 | 05:33 PM
Nthe11s's Avatar
Nthe11s
Is the car turning over? if it is check your Crank Sensor plug next to the AC compressure those are known for haven a bad connection. If that does not work check your Fuel pressure switch.
Old Feb 14, 2007 | 05:39 PM
mariotraci's Avatar
mariotraci
yeah i did a seach and got that one to thank you
Old Feb 14, 2007 | 06:09 PM
mariotraci's Avatar
mariotraci
Which wires do I test going into the gas tank to see if there is power there? Im going to go to Auto Zone and buy a chiltens. When I had the tank open I could watch the pump move when the key got turned on. I can spray starting fluid and I get fire. The new pump does the same thing the old pump did. As far as the crank sensor, is it the gray plug in front of the motor, do I just unplug and plug back in? It's got a wire going into a little black thing on the front left side of the motor.
Note - the car started off and on for two days and then just completely quit (if that means anything). I just put a new pump in...same thing. I can still hear a clicking noise back there but nothing.
Old Feb 14, 2007 | 06:47 PM
8banger's Avatar
8banger
Does your anti-theft light flash when the key is in the run position....?
Old Feb 14, 2007 | 07:26 PM
V1PWRED's Avatar
V1PWRED
look in your trunk on the drivers side towards the back mayby behind the carpet. there is a fuel pump cut off switch that may have tripped. this same thing happened on my 01 gt. pushed the button all fixed
Old Feb 14, 2007 | 08:02 PM
mariotraci's Avatar
mariotraci
yeah theft light blinks in patteren
Old Feb 14, 2007 | 08:07 PM
8banger's Avatar
8banger
Possible PATS problem.....
Old Feb 14, 2007 | 08:34 PM
mariotraci's Avatar
mariotraci
ORIGINAL: 8banger
yep found original key fired right up.thanks pump later but its got a new one now thanks guys
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 08:51 PM
SYNY5TER
Sep 2, 2015 01:35 AM
