weird Problem with traction control??
Old Feb 22, 2007 | 06:02 PM
StriktlyGT's Avatar
StriktlyGT
Default RE: weird Problem with traction control??
Maybe it'shappening now because your tires aren't gripping as strong anymore. Personally, I don't accelerate hard with the traction Control on. Actually I never drive with it on either. If you can afford to turn it off and drive with it off (assuming so if you're accelerating that hard) then leave it off. Hard acceleration in a mustang kind of defeats the purpose of Traction control.
Old Oct 23, 2007 | 11:46 PM
mmx_170's Avatar
mmx_170
i have a 99 gt also and i have a similar problem, i had put 92 octane gas in and it started hesitating a bit under hard acceleration above 3000rpm so i figured it was the higher octane doing it but on the way home today i took traction control off their wasno hesitation at all, so im now guessing it isa tration control issue but im not 100%, did the 1999's have problems with the trac. control or something?
Old Oct 24, 2007 | 12:19 AM
swooshonln's Avatar
swooshonln
wait... it CANT be this simple
Your traction control is kicking in because your tires are slipping..... and your car is retarted for a few seccond to keep you from loosing control. After a few secconds the green "tire" goes off and you continue to accelerate
what you are describing IS traction control. If you turn it off, you should not have that problem....
Old Oct 24, 2007 | 07:09 AM
Eagle2000GT's Avatar
Eagle2000GT
If I'm not careful my traction control kicks in every once in a while. The light is a green wheel, not the check engine. I have never had it affect the front wheels or create a steering problem. I think you may have something different happening.
Old Oct 24, 2007 | 12:43 PM
mmx_170's Avatar
mmx_170
for mine the tire slip light isnt coming on when it starts to hesitate a bit and i doughtthe tireswould spin in 4th at 3000rpm(it is stock)
Old Oct 24, 2007 | 01:20 PM
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
sounds like a spark/fuel/air issue. start with the air and fuel filter.. check the plugs and packs.. the hesitation is most likely a misfire or detonation. have you heard any deep pop noises from your hood? let your car idle and listen for anything that sounds weird (pop, metallic ping, thump, etc.)
Old Oct 24, 2007 | 02:36 PM
mmx_170's Avatar
mmx_170
theres no hesitation with the trac. control off, so thats why im leaning towards a problem with that
Old Oct 24, 2007 | 03:20 PM
wwmost's Avatar
wwmost
thats traction control kicking in. the light you are seein is the light that says the traction control activated.
Old Oct 24, 2007 | 04:09 PM
mmx_170's Avatar
mmx_170
the lights not coming on, and im pretty sure im not loosing taction at the point its doin it
Old Oct 26, 2007 | 08:13 PM
mmx_170's Avatar
mmx_170
ok its one of my injectors thanks anywyas
Pyrate Dave
Sep 10, 2015 07:30 PM
Dragonus18
Sep 9, 2015 01:21 AM
zachary1988
Sep 4, 2015 03:04 PM
cbird1177711
Sep 2, 2015 04:12 PM
iculookin
Sep 2, 2015 12:34 PM
