voltage of Throttle Position sensor
Old Oct 27, 2004 | 12:24 PM
supercharged96gt's Avatar
supercharged96gt
Default voltage of Throttle Position sensor
I am changing out my 70mm TB and stock plenum for a 75MM TB and ported and polished plenum today. I need to know what the voltage needs to be when I switch the throttle position sensor. I heard a while back something about closest to 1 volt with out getting here ex. .99 volts but I can't remember if it was at idle or car off and pedal to the floor. Anyone know
Old Oct 27, 2004 | 12:34 PM
cammedlx's Avatar
cammedlx
Default RE: voltage of Throttle Position sensor
on the 4.6 stang,the tps is none adjustible,the only thing you do is bolt it on,and your done
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
key on engine off .98 or so
Old Oct 27, 2004 | 12:35 PM
cammedlx's Avatar
cammedlx
i thought that you did not have to adjust them[8D]
Old Oct 27, 2004 | 12:37 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
your not "supposed" to have to, but installing aftermarket throttlebodies, adjusting the idle, etc. often requires you to
cammedlx's Avatar
cammedlx
Thanks for clearing that up MD
Old Oct 27, 2004 | 12:45 PM
supercharged96gt
Hey thanks MD
Old Oct 27, 2004 | 02:20 PM
rtm's Avatar
rtm
Instead of probing for voltage, just unplug and read the resistance across the sensor. Then set the other accordingly.
It's the way I did mine. Then you don't have to penetrate any wires.
Old Oct 27, 2004 | 03:47 PM
supercharged96gt
Hey rtm what should the resistance be then I am not familiar with what it should be. What 2 of the 3 contacts will I be testing too.
Old Oct 27, 2004 | 03:55 PM
rtm's Avatar
rtm
I can't remember which of the three you use, so just read all of them off of your sensor while it is on the stock TB.
Probe pins 1,2---1,3---2,3. Write down the resistance you read between them. Then when you put the sensor on the new TB, snug it down, re-read the pins and adjust until they are the same as the stock readings.
Just set your meter up to read ohms. It is the symbol shaped like a horseshoe. Set the scale to read two decimal places.
I don't recall ever seeing a range of what it should be when dealing with resistance. Just voltage.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
