misfire on #6
Old Feb 24, 2007 | 06:22 PM
nathansmith50's Avatar
nathansmith50
Default misfire on #6
well i know what it's doing and where......now i just need to figure out why.
after sitting mostly idle for about 2 months i have a miss on #6 cylinder.
what is most likely the cause? and which is #6 so i can start trying to fix it.
Old Feb 24, 2007 | 06:25 PM
Nitti00GT's Avatar
Nitti00GT
Default RE: misfire on #6
I believe it's thesecond one on the driver's side. Third from the firewall.
Old Feb 24, 2007 | 06:42 PM
04BlueGT's Avatar
04BlueGT
Check the plug and the coil. Most likely one of them is bad. Easy way is to swap coils and see if the problem migrates to the other cylinder.
Old Feb 24, 2007 | 06:44 PM
99lolagt's Avatar
99lolagt
It may be the coil my #5 did the same thimg. The coil is like 90 bucks at the dealer.
Old Feb 24, 2007 | 06:54 PM
99gtstang's Avatar
99gtstang
ORIGINAL: nathansmith50
my # 5 and 6 went bad........... coil packs you can get them for about 45 if you look around ... easy to change out
Old Feb 24, 2007 | 07:33 PM
35thGT_Mustang's Avatar
35thGT_Mustang
My coil pack on my #6 cylinder about a week ago. Also, you can check the coil pack boot to see if it is warn. a new boot is alot cheaper than a coil pack!!
Old Feb 24, 2007 | 08:06 PM
nathansmith50
ORIGINAL: 04BlueGT
i don't have a tuner......so that's out. because it would be a lot of trouble to swap and then drive back to autozone.
anyone know the cylinder numbers?
Old Feb 24, 2007 | 09:46 PM
Nitti00GT's Avatar
Nitti00GT
ORIGINAL: 99lolagt
Yeah my friends 2000 GT's coil on cyl #8 like blew up. It was still connected and somehow the bottom of it was out the top and it bent itself out of the spark plug well. Went to the dealer and 97 bucks for a new coil. His car is now dead and at the dealer.
Old Feb 24, 2007 | 09:59 PM
Fryguy22's Avatar
Fryguy22
ORIGINAL: 04BlueGT
just swap it at autozone.... they'll probably do it for you.
Old Feb 24, 2007 | 10:03 PM
nathansmith50
ORIGINAL: Fryguy22
ORIGINAL: 04BlueGT
autozone doesn't.....i could take it somewhere else and have them do it......but i'd rather save the cash and do it myself......not to mention i'd just rather do it myself.
Urambo Tauro
Jun 10, 2016 03:28 AM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
bconboy
Sep 21, 2015 12:52 PM
chrisc
Feb 10, 2006 10:16 PM
ghoste
Sep 7, 2005 11:42 AM
